Le Deal du moment : -21%
LEGO® Icons 10329 Les Plantes Miniatures, ...
39.59 €
 Restau de Mamie RD350 1973
Phil31
Papimoto
San Francisco
14 participants
Aller à la page : Précédent  1 ... 9 ... 14, 15, 16
Restau de Mamie RD350 1973 - Page 16 Empty
MessageSujet: Re: Restau de Mamie RD350 1973   Restau de Mamie RD350 1973 - Page 16 EmptyLun 6 Jan - 14:07
Oui ils en parlent là
"The exhaust manifold contained vacuum-operated butterfly valves that were open during acceleration and normal running but closed and mostly blocked the exhaust when the throttle was shut, significantly reducing the flow of unburned hydrocarbons into the exhaust stream. All this made the Daytona Special run hotter, but the shrouded cylinder head effectively aided cooling, and quieted the engine, as well. Changes to the porting improved the midrange and made scavenging more efficient, and the Daytona got a mild bump in compression."
Mais il n'est pas visible sur leurs photos.
Restau de Mamie RD350 1973 - Page 16 2020-011
Page 16 sur 16Aller à la page : Précédent  1 ... 9 ... 14, 15, 16
» moteur RD350 1973 compatible avec carter RD350 1974 ?
» Cherche 1 disque garni pour ma RD350 1973
» On en parlait au restau à Péronne
» Remise en route de Mamie YR5 de 71
» Demultiplication RD350
